Problem with fuel tank
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by caryhenry, Nov 24, 2002.
  1. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    My gas tank is leaking from what appears to be the rear seam of the tank. Does anyone know where I can find a cheap 31 gallon tank for an 85 4wd. Please let me know. /forums/images/graemlins/confused.gif
  2. dyeager535
    26,982
    191
    Well, www.natauto.com has them for about $135, not sure if thats cheap to you or not. Only other option is finding one off a parted out truck. They aren't prone to failing really.
  3. Grim-Reaper
    7,385
    Atlanta
    JC Whitney also has them. They are pretty cheap.
    You sure the sam is leaking and not a hose on the top? They will drain off the back if a hose is leaking.
  4. caryhenry
    Sep 28, 2002
    78
    Tallahassee, Fl
    I don't think it's a hose cause it's not wet above the seam of the tank.
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    You might check out autozone. They sell gas tanks. Dont know how good they are though.
