Problem with headlites
Discussion in 'The Garage' started by cheyennesuper, Aug 26, 2005.
  1. cheyennesuper
    cheyennesuper Registered Member
    Nov 2, 2004
    52
    Wisconsin
    I just bought an '87 chevy custom delux pickup and i installed the whole front-clip off my old '73 K5 on it.When i turn on the headlites only the driver side bulb works,but when i click on the brites the driver-side bulb shuts off and the passenger side turns on.Anyone have any ideas???Any help will be greatly appreciated. ~Eric
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Before you spend much time troubleshooting the wiring, make sure that you are using 2 good headlights. It could something as simple as one light having a burned out low beam filament, while the other one has the high beam burned out.
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I always seem to have problems with the sealed beam sockets. They corrode too fast. Check the connections to the headlights, and make sure headlight filaments are good (test on battery). Then maybe look at switch. Then trace wires, might be corrosion there too. Just start elimiating one by one.
    Good Luck...
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's not the switch, as the lights are wired in parallel. One wire feeds both low beams, one wire feeds both high beams. Neither side would work if the switch was hosed...
  5. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    True, true, I typed before I thought about it. Thanks for the correction.
  6. cheyennesuper
    Nov 2, 2004
    52
    Wisconsin
    I'm gonna just start by getting new bulbs and hope Harry's theory is right.Thanks guys.
  7. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i fu have an ohm meter test em, or use a juper and test it that way, so u dont waist money imo
