Problem with part #'s for Front Dana 60
Discussion in 'The Garage' started by Shagnaz, Apr 12, 2003.
  1. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    Problem with part #\'s for Front Dana 60
    I just got my Detroit locker for my front Dana 60. So, I pulled everything down and I am needing the seal for the axle tube. It's called a Seal & Guide tube. I called the parts store w/ the # that was on a post, but we don't know what brand the seal is.
    Also, anyone know the torque specs on the front hubs?
    I have two different sequence on doing it, but don't know
    what is right.
    The first one is 70 pounds...back off 90 degrees...35 pounds and than back off 3/8's of a turn.
    The second one is 50 pounds and don't back off anymore than
    1/4 turn. I guess you have to feel if there is any drag.
    Please help...I am going on a trip to North Carolina next weekend. Gotta get this thing back together soon.
    THANK YOU!!!!!!!!!!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    Mike B
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: Problem with part #\'s for Front Dana 60
    I set mine by the 50lb, 1/4 turn. No problems for 1 1/2yrs.
  3. Shagnaz
    Jul 19, 2002
    308
    Did you set it at 50 lbs. and then back off 1/4 turn? And left it at that?
  4. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Yes, you back it off just enough to get the lockring in place.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the danger with that is that it may take more then 50# to seat the bearings.
    basically
    1- you crank it pretty firm to seat the bearings
    2- then back it off
    3- then set free play (or preload in some cases, check the manual. when in doubt I would err to freeplay)
    a torque wrench is not required at all, and using the above 50# number may lead to a bad experience.
    I think in this type stuff it is important to know the 'why' and the 'how' becomes evident.
  6. Shagnaz
    Jul 19, 2002
    308
    I had the steps to do the correct torqueing, but I lost them. Ciltons says, well it's in my orginal post, but the
    Dana Spicer says the 50#. I thougth I had it wiped, but I
    took it out on the highway and it was warmer than the driver's side. I am going to break everything down again and redo it. Repack the bearing etc...
    Gotta get ready for K5 Crawl. I am driving up there from
    Charleston,SC and on top of that I am going this weekend to
    Uwharrie to do a clean up/wheel. Late night, here I come!
    Mike B
