Problem with the 72 K-5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 72K5BEAST, Jan 4, 2002.
  1. 72K5BEAST
    72K5BEAST Registered Member
    Dec 28, 2001
    15
    Oklahoma
    Well, my truck is still acting up. When i turn my truck off it sputters and clunks around and has backfired but only twice since august. Thanks to everyone that helped me with the choke problem because i got that all worked out. However, my truck still sputters and clunks when i turn it off. As a temporary solution someone told me to turn it off while in gear. That worked for about a week but today when i got to school i turned it off in drive and it still sputtered...so i'm thinking it's gonna be the carb? If anyone has any recommendations on how to fix this and/or what I should do about my carb (whether it be re-build the thing or get a new one, in which case i'd really appreciate what kind [i have a quadraJUNK right now]) That's about it, thanks alot for all of the help.
    God Bless
    Charlie
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i still think its a timing problem...it sure sounds like it is from what you are describing
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Did you do a basic tune up on it yet? (Cap and Rotor, Plugs and wires, and as everyone else said Timing) May also be a Vac leak. Check all vac hoses. I had one crack off and the same symptoms happened. I felt around and plugged the California emissions crap back in. It runs like a champ. Good luck KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
