Problems after Mods
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Dec 14, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I installed a new alum. intake, headers and the holley truck avenger. Now my truck won't start. It is back firing through the carb. I figure it is something with my timing . I started at top dead center at the #1 piston and saw which wire it was pointing to and ran my wires frome there. 1863......
    It is still doing it. Is it possible I have the distributor cocked a little. Where should my #1 wire on the distributor be pointing 6:00 or 5:30. Should I lift the distrib. out completely and reinstall it at 6:00. Please help winter is coming fast.
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Did you mess with the dist. at all when doing these mods? If not it might have something to do with the carb, possibly it is messed up out of the box.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It sounds like your distributor is 180* off.
    Harley
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    1863..........
    No , the firing order is matter of factly 1-8-4-3-6-5-7-2
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    my vote is the distibutor is out 180*also
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I caught that too. ;)
  7. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i vote the dist. is out of wack. :D
  8. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Distributor 180 out and timing out of order
  9. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    firing order! one wire wrong will make it backfire.
  10. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    I'm also betting the distributor. I had the same problem did all the same upgrades he did, except I couldn't get the distributor back in the right spot, when I finally hit the sweet spot she started up but then I ran into more problems but that's a whole other story.
    EAT BEEF
  11. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    I have my firing order right I was trying to remember off the top of my head. The firing order was stamped on the original intake. I was asking if anyone knew give or take where the distributors #1 wire should be pointing. 5 oclock, 6, 5:30. This might help me figuring out what kind of change I have to make to the dist.
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    #1 is typically pointing at the #1 cylinder. So thats kinda 4:30ish.....
  13. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    It shouldnt matter exactly where the #1 wire is, as long as the rotor is pointed at the #1 spark plug wire it will be fine. Have you set your timing? Is it still backfiring?
    Later
  14. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    I can't even start it. It is backfiring through the carb.
  15. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    I second the 180* theory. Flip your dist. around. Even if that's not it, it only takes a few to eliminate the possibility.
  16. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    I flipped it around, no dice. I hate being broke down. Sometimes flames will shoot out of the carb. My firing order is good. Any other suggestions, PLEASE!!!!
  17. zeroz400
    May 30, 2004
    410
    Libertyville, IL
    Do you have spark? All your wires secure? If its backfiring through the carb you are either 180ºs off or your 5&7 spark plugs are flipped the wrong way.
    Later
  18. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    From GM Service Manual:
    Installation-Engine Disturbed:
    1. Locate No. 1 piston in firing position by either of the two methods described below:
    a. Remove No. 1 spark plug and with finger on plug hole crank engine until compression is felt in the no. 1 cylinder. Continue cranking until timing mark on crankshaft pulley lines up with timing tab attached to engine front cover.
    b. remove rocker cover, (left bank on v-8) and crank engine until no.1 intake valve closes and continue to crank slowly about 1/3 turn until timing mark on pully lines up with timing tab.
    2. Postion the dsitributor to opening in block in normal installed attitude, noting postion of vacuum control unit.
    3. Postion rotor to point toward front of engine (with distrbutor housing held in installed attitude) then turn rotor counter clockwise approzimatly 1/8 turn more toward left cylinder bank and push distributor down to engine camshaft. It may be nessesary to rotate rotor slightly until camshaft engagment is felt.
    4. While pressing firmly down on distributor housing, kick starter over a few times to make sure oil pump shaft is engaged. Install hold-down clamp and bolt and snug up.
    5. Crank engine by hand to put no.1 piston back in firing position according to step 1. Place distributor cap in position and check to see that rotor lines up with terminal for no. 1 spark plug.
    6. Install cap, check all wire connections.
    7. Connect vaccuum line to distributor.
    8. Start engine and set timing as described in tune-up section 6.
  19. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    make sure you wires are going in the right order clockwise 1 8 4 3 6 5 7 2
    also 1 is the drivers front, then 3 5 7 on drivers side 2 4 6 8 on pass side.
    If you wires are in order, try jumpin all the wires 2 posts clock wise on the dizzy and see if it starts, if its firing through the carb its too advance, throught the pipes its to retatred
