problems!! i need help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Mar 27, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    today i was driving home from school, and when it was shifting into 3rd gear [appx 30 mph] it would like reve the engine, then kick into 3rd. then it did the same from 1st to 2nd.
    its like its stuttering then the engine revves on its own and kicks into gear.
    and then i go to back in my drivway, nothin! i put it in reverse, hit the gas, and went no where. all i got was a rev of the engine. AGAIN! i waited, then tried again and it worked
    when i got out andit was in park, but was still on.... it makde this wierd ass noise. like a rattle. it was like a buzzing. i need help on this problem asap!!!
    thanks
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Sounds like a tranny problem. Is the fluid at the proper level? When's the last time the filter was changed? I hope it's something simple and you haven't toasted your tranny. I'm assuming it's a 700R4.
  3. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    it should be a stock trny in a 85
  4. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    the noise sounds like its coming from the drivers side of the engine.
    its louder when the hood is shut
  5. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Mine did that about a year and a half ago. It was my tranny (700R4). Just simply was worn out and decided not to shift anymore. I had to have it rebuilt because it was so far gone...(kinda figured that out when the fluid came pouring out it- DOH!) But that's what I would check if it's doing what you said....good luck and hope it's something simple and not a rebuild you need! :-)
    Stephanie
    &lt;&gt;&lt;
    "I love the sound rice burners make when ya run over them"
  6. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Change the filter and put fresh ATF in it
    and see what happens, It will probably be better
    but, don't know for how long,
    also can check your modulator line for any cracks or kinks etc
    other than that, its probably shot!
    Hope Not!
    If it ain't Intimidating / It ain't a Chevy!
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>It sounds like it finally took a crap on you ...... same simptoms all my trannies had when they died.
    L8r,
    . Riz . <A target="_blank" HREF=http://www.geocities.com/rizmonkey>http://www.geocities.com/rizmonkey</A>
  8. Storm Trooper
    Nov 24, 2000
    4,640
    I assume it's an automatic?
    1st, pull the dip stick, does it smell burnt?
    If so, pick up new fluid and a filter and change them!
    If you don't have the money for a rebuild you could try some additives but it will only prolong certin death and probaily in the worst place. You will I'm sure end up rebuilding it.
    If you do though, look on the bright side, if you can find a good tranny man, add a nasty shift kit, a high stall torque-inverter and you can have a neck snap'in tranny. If your tough on it, its better to have it shift quick. Good luck!
    also keep in mind, it's cheaper to rebuild it before you shell it.
    [​IMG]<font color=red>Rid'in High In My K5[​IMG]
