Problems of a Throtle Shaft Leak? and inj pump marks.
Discussion in '1982-Present GM Diesel' started by Jaguargt, Jul 25, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    could be rough idle one of the problems of a leak in the throtle shaft?, lack of power?, what else?,
    the marks in the front cover and the inj pump are not aligned, and the engine it's too noisy, should i align the marks? thanx in advance. /forums/images/graemlins/confused.gif
  2. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    The marks indicate timing. If the pump mark is to the left of the timing cover mark, then the pump is advanced.
    If it's to the right, it's retarded.
    As the engine ages, the pump can be advanced to help make up for the timing chain stretching.
    To set timing properly, you apparently need a luminosity light.
    Playing with the marks by ear is a bad thing.
