problems running, HELP!
Discussion in 'The Garage' started by 76blazerguy, Apr 8, 2005.
  1. 76blazerguy
    76blazerguy 1/2 ton status
    Nov 15, 2004
    125
    wichita, Kansas
    i just bought installed a new intake manifold and put everything back together. I dont think i have left anything or fergotten anything. It turns over and begins to idle, then there is a bang and smoke exits from the carb. its a grey smoke. I dont know how to describe it other than a back fire. The truck then shuts off. Just incase you need to know its a stock 350 with verylittle modifications on it. Any ideas guys????
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Sounds like you got the distributor in 180 out or the initial timing is way off or you could have a couple wires crossed.
    Are you sure that the motor is not sucking air from somewhere besides the carb. ?
  3. bigcat44
    bigcat44 Registered Member
    Jan 29, 2005
    59
    Albuquerque
    went through this same crap the other day. Start with your hoses, be sure they are connected correctly, then check your distributor and wires. Before you flip your distributor, adjust your timing to see if that corrects it. With my dist flipped 180 out my TBI Jimmy would not start.
  4. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    ok well i got it running, and idles good. The only problem now is when i give it some gas it backfires out the exhuast now. I have never had that problem before so im confused what is making it do it now. Is that still a timing issue??
  5. bigcat44
    Jan 29, 2005
    59
    Albuquerque
    Sounds like it is a timing issue
  6. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Advance the timing some more....and check to make sure the rockers are'nt overtightened (zero lash + half a turn)
  7. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    all fixed guys, and loving the intake now. thanks for everyones help
