problems running right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, May 25, 2002.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 350 tbi and when i start it up in the morning it runs mint, idles great and it smooth after 5 minutes the idle will jump all over the place and it will be surging i have replaced the fuel pump, fuel filter, strainer, plugs, cap, rotor, wires, coil, egr valve, o2 sensor, pcv valve, if someone could help with me it would be appreciated, thanks.
  2. abusedtrucks
    abusedtrucks Registered Member
    May 11, 2002
    76
    Upsala , MN
    Take it to a shop.
    hehe...
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Jeez, does anybody have any ideas??? It sounds like the brother has replaced all the parts that could cause this problem.......
    I'd be curious to hear what others say because my brother-in-law's 91 is doing something similar.
  4. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    have you used a code checker to check the codes?
  5. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Does the Service Engine Soon light come on? Are you getting an EST error code? Did you check for DTC'S? It loses power after it gets hot, Is the Catalytic converter restricted?
  6. YtseJam
    May 19, 2002
    147
    CT USA
    Also check for a vacuum leak @ the base of the Throttle body. Spray carb clean at the base of the TBI and see if the idle changes, The base gaskets get sucked in and cause a large vac leak, the IAC tries to compensate.
  7. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    I had the samething on my 87 it was the water temp sensor
    Try that.
