Problems With 14 bolt Discs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wakedog, Dec 4, 2001.
  1. wakedog
    wakedog 1/2 ton status
    Mar 7, 2001
    233
    Minnesota
    I have the caddy calipers on their and they are leaking out out the e brake arm, what can i do to fix this?? Also i have to put my foot to the floor to stop now, i know about bleeding the brakes, but this has happened before and the fluid was low,, when i filled it back up the pedal would stiffen back up to normal but now the fluid id ful and it still goes to the floor. Any ideas?? Thanks
    <a target="_blank" href=http://www.bigredjimmy.iwarp.com>http://www.bigredjimmy.iwarp.com</a>
  2. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    yes there is a rubber bushing inside those holes where the e-brake arm goes through, if the calipers sat for a long time w/no fluid in them they may have dried out and cracked, i have taken them apart before but it was a BITCH!, you would probably be better off to buy remanufactured units for 40.00 ea. by the way, i am putting a 14 bolt in my 1990 next week but i am only the seville calipers which may be too small which ones are you useing? how much did you spend on your tsm brackets and which disc did you use? thx j.c.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check out this thread <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=83174&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=83174&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a> It may be helpful.
  4. wakedog
    Mar 7, 2001
    233
    Minnesota
    I am using the deville calipers, they are reman units that are not more than 5 months old. The tsm kit ran me 299 with brackets and ford rotors.
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    remans that leak, take em back
