Problems with 465 trany.
Discussion in 'The Garage' started by jk3078, Mar 27, 2006.
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    About 6 months ago my trany started giving me problems. What happened is I put it in reverse, backed up and when I pulled it out of rev. to get first it woudnt' go into a forward gear only back into rev. No matter where the stick was at the trany was stuck in rev. So I pulled the stick and monkeyed with it in and out a few times and wiggling it around some to and it started shifting again. This has happened about 10 times after that and I'm afraid that the next time might be the last time. Other than this the trany works fine, has good input/output shafts ( just swapped it in last summer), so I'm hopeing its somthing simple. Any ideas? Thanks guys.
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Is it hydro or mech clutch? When parts of my clutch system starts going out, it doesent like rev or granny gear. I did it really bad when my master cylinder when out on the way to TDS.
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    yeah made sure when you depress the clutch pedal it is acutaly doing the same at the clutch and disengaging, i had similar issues too when my clutch crapped out at tds :D
  4. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    No, the problem is internal. I have a newer centerforce II with a dual friction disc and all of my linkage is adjusted properly and in good condition. I understand the non-syncro first and reverse but this problem is more like a binding in the shift rails or somthing. Anyone deal with a problem like this before?
  5. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Anyone?
