Problems with a 12" suspension lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, May 23, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Problems with a 12\" suspension lift?
    I knew it was going to happen. Now I want to put a 12" suspension, 3" body, and run 44" Boggers. I knew it was going to happen sooner or later. Now, what kind of crap am I going to have to do about the driveline? I think it's going to take a hell of a lot more than just grinding and CV's. I'm serious about doing this too. There isn't a single Blazer here in Wichita that has 44's on it. I want to be able to dominate! I think "BigBurb" would be the guy to talk to, so I hope he replies here.
    p.s. Don't bring up that, "you're going to need to get bigger axles," crap. I know, and don't worry, I'm already taking care of that now. hahahaha
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Re: Problems with a 12\" suspension lift?
    I would call Jesse at high angle driveline to get your hands on a 80 deg. cv. The problem is he's hesistant to make the unit for a 208. I read your profile and you have an 88' with a 700r4 so I am ASSUMING you still have the 208. If that fails call Tom Woods. Dont forget about steering issues, you will probably need a cross-over steering setup. And ,skimp not, on your brake cables/lines. Oh yeah, [​IMG][​IMG] you will need to upgrade your axles!!!![​IMG][​IMG]
    [image]http://www.hkpro.com/action3tacnor.jpg[/image] Dont steal my truck..I dont need anymore worthless junk over my fireplace.
  3. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Why so much lift?
    I've got a 3 inch body lift on the Blazer. A ~5.5 inch suspension lift will be going on the truck shortly. And I plan on running 44 inch rubber. Everything measures that is should fit. In fact, I was debating taking some of the lift out.
    --Rob
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Alex, you are one crazy dude!!! [​IMG] [​IMG]
    Must be a "size issue" you have with the ladies!!! [​IMG] [​IMG]
    When In Doubt, Whip It Out!
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I hate to burst your bubble homey, but I was at a car show last weekend and there was a Blazer, from Wichita, with 44 inch Boggers on it. It was white with strobe lights on it. Kinda stupid, but it still had 44's on it.
    All I can say is you better find a Dana 60 to match that 14 bolt in the back if you go ahead and do this.
    '73 K5
    Chevy good...Ford bad
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well w/ 44's... yes Wes it sounds like a size issue LMAO [​IMG]. I'd say ditch the 208... you need best of the best... If it is my rig I settle for nothing short of a 454, TH400, 205... D60 and 14B FFw/ some major gears. Probably looking at a 2" drop of the tcase and then some beefy 80 degree shafts or possible a double cv shaft depending what you can get done w/ driveline angles... cut and weld the perches... ummm and probably about twenty more things...
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
  7. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    At times like this I envy you Americans. Here in the Netherlands I already spend a good 20 weeks, finding me a 6" lift for my '88. It is so frustrating that at times, that it almost made me sell the Blazer.
    "K5 Grand GT Blazer Silverado in the Netherlands."
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Can't you find someplace here in the States and do a simple mail order? Surely someone could ship the kit to you way up there in 'Neverland'!!! [​IMG]
