problems with crossover
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazing86, Apr 21, 2002.
  1. blazing86
    blazing86 1/2 ton status
    Dec 24, 2000
    290
    I started my crossover steering project using knuckles off of a 76 3/4 ton truck. I got the knuckles on and tried to attach the draglink and realized the taper was from the top and not the bottom. The draglink would hit the bottom of the leaf springs. So now im having to go to high steer, which is costing me more money. I just had to vent, i always end up spending to much money.
  2. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    You could drill out the hole and use heims. Maybe.
  3. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    DO WHAT CHAD SAID.
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    You could also install a 0-rate....maybe even a custom one that is cut at the angle you need to eliminate the cheesy (aluminum type) degree shims.
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Are you talking about the tie rod?
    My tie rod is on top of my knuckles like yours which was no problem til I got my rock rod.The extra diameter of the rock rod caused it to rub the bottom of my springs some times.I fixed this by making a 1/4"flat stock spacer that bolted to the bottom of the spring pack with the center pin.Materials probably cost about $1/forums/images/icons/smile.gif
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ok heres the deal,all you need for this to work is a tie rod from a 73 to 80 1/2 or 3/4 ton or blazer,the ends are dropped so it will clear the springs.im betting you have a tubular tie rod on there now right?the earlier tie rods are solid with different ends.hope this helps
    shane
