Problems with DD please Help
Discussion in 'The Garage' started by babyburb, Dec 11, 2006.
  1. babyburb
    babyburb 1/2 ton status
    Oct 24, 2006
    2,344
    1H North of Dallas
    I finished swapping out engine from a donor truck in my 99 ranger 3.0 v6. Same motor swap but I had to put in throw out bearing to fit my manual 5 speed. Now I have no clutch at all. When started, it will not shift into or out of any gear. You can put it into a gear when not started, start it up and have that gear but it will not come out. Any ideas?:confused:
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Was the donor engine an auto or manual tranny.?
    If it was auto, did you install a pilot bushing?
    Sounds like you need to bleed the hydraulic clutch system. How does the pedal feel?
  3. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    It came from auto but I did install the pilot bearing. My uncle and I blead the clutch system for over and hour. Still nothing.
  4. babyburb
    Oct 24, 2006
    2,344
    1H North of Dallas
    before the swap the pedal felt like a spring was attached, now there is no resistance at all on the pedal.
