Problems with Hydroboost(leaking) on 92 Suburban
Discussion in 'The Garage' started by TylerT, Sep 28, 2005.
  1. TylerT
    TylerT Registered Member
    May 30, 2005
    40
    OKC
    I'm starting to think I really made a mistake buying this truck. I'd love to get everything running well, but stuff keeps coming up. I heard a whining noise when steering yesterday. Went and looked at my ps pump, no fluid. So I filled it up, and ran it, only to find a nice leak. After searching all over for the source, I finally found it. Right where the master cylinder bolts to the hydroboost, uh thing. You know the thing that the hoses from the ps pump run to. I took the master cylinder off, and there's no gasket, none of the parts stores carry a gasket for that. Local GM dealer looked it up and they showed me a 'spacer' that I needed. Anybody have any experience with this system? 92 Sub 3/4ton, 454. Thanks a million in advance.
  2. TylerT
    May 30, 2005
    40
    OKC
    After doin a little bit of searching, I think I may have to replace the unit..can anybody confirm that? I do have to disconnect it from the inside of the firewall, right? Thanks
  3. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    609
    Hooper, Utah 84315
    Yes it does come off from the firewall and the bolts or nuts are inside up by the brake pedal and if you want some experience before doing yours I will let you come and do mine. :D
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    with basic hand tools, and about 30 min, I did mine.
    Hydroboost is great. Unfortunately, there are two problems that seem to occur-
    1. Leaks- sometimes the little cylinder to its side pops off its thread. Not too much you can do about that, except use some thread tape, and try and screw it back in. It still may or may not stay.
    2. The seals leak. You'll find leaky seals, the nice sized leak is from the little gap, right where your finger can reach under.
    I took my old one apart- it is not as complex as you might think it is, and is really only about 5 seals- be careful when removing the rod though, it will shoot right out. Have a rag to catch it.
    the rebuilt mega buck unit (I think it was about 300 bucks+ 100 core) just comes with new seals.
    I keep a spare around, since I have two hydroboost trucks, but if you want to save a few bucks, you can mail me yours, and I'll exchange it at autozone for a new one. LOL. (Lifetime warranty baby).
  5. TylerT
    May 30, 2005
    40
    OKC
    The little cylinder to its side, I'm still looking for that, what is it's purpose? Oh, and will the one from Autozone be any good? That one's not $300 is it?!
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Cylinder is a small hydraulic accumulator...gives you a couple of assists with the brakes when the engine stops, pump dies, etc.
