Problems with Steering Brace Again....(updated with pics)
Discussion in 'OffRoad Design' started by BlazerGuy, Jul 27, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Ok, so the holes don't line up perfectly on the crossmember but only by a 1/8" or so. So I widen the small hole to 1/2" and was going to try to wallow it out on one side to make the 1/2" bolt fit. BUT I realized that if I wallow it out the bolt will not be secure enough for the brace to be effective. My question is can I use a smaller grade 8 bolt(3/8?) instead of the 1/2" grade 3 bolt? I know it's kinda hard to understand <a target="_blank" href=http://www.k5.rockcrawler.com/images/mvc-011f.jpg>Click here to see a pic</a>... Thanks
    &lt;a target="_blank" href=http://www.k5.rockcrawler.com&gt;Click here to see my K5&lt;/a&gt;
    *<font color=red>under construction</font color=red>*
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by BlazerGuy on 07/27/01 10:56 AM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;&lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by BlazerGuy on 07/27/01 10:57 AM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by BlazerGuy on 07/27/01 08:20 PM.</FONT></P>
  2. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I took it for a test drive with the 3/8" grade 8 bolt in place of the 1/2" bolt and my steering wheel isn't cocked to the side anymore [​IMG] I think I can get a 7/16" bolt to fit in there also for a little more strength.
    <a target="_blank" href=http://www.k5.rockcrawler.com>Click here to see my K5</a>
  3. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I had to start a totally new hole. The two holes eventually connected but the bolt was still secure.
    Chad
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It looks like the hole was already drilled out for the 1/2" bolt before the brace was installed. If it's not going to line up, I like to use a die grinder to cut the hole in the right direction. To fix this, you should probably cut the hole to where the bigger bolt will fit and look around for someone to either weld the hole shut and re-drill it, or weld a patch over it with the 1/2" hole in the patch and use a little longer 1/2" bolt.
    Going with the smaller bolt will be functional, but not as strong.
    Making the world better, one truck at a time.
    SW-ORD
  5. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks Stephen!
