Problems with the pass. D60 axle tube
Discussion in 'The Garage' started by zakk, Jun 5, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Tired a search for this info and suprisingly there was nothing.....
    The passanger side axle tube is bleeding pretty bad. Does anyone know the P/N for that axle seal?
    Also, if i had the gears redone and paid for a master install kit from Yukon, would this seal have been replaced??
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Any place that does a gear install, should have replaced that seal.. for my friends hp60 we had to go through 6 states to get them axle seals, do you guys have a six states distributors, down there?
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    oh yea i forgot to ask, Have you replaced one of those before? your gonna have to take the axle shafts out of both sides, remove the carrier, and use a long ass pole to tap that seal in there.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Although it makes sense to replace the differential seals when the gears are replaced, I don't think any of the master install kits include these seals. I doubt they were replaced with your gears.
  5. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Six States has them for $5.46 a side. The spicer pn is 36487. If you have a Checker or one of their sister stores they sell chicago rawhide and they are the exact same part. The last spicer seals I got were exactly the same as the Chicago Rawhide seals right down to the CR stamped on the metal. Plus they are made in the US.
  6. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    One question -- is it leaking from the end of the axle tube, or is it bleeding between the differential housing and the axle tube?
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    end of the exle tube...
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    on corporate front ends and D44's we call that the self oiling ball joint option and on D60's the self oil kingpin option /forums/images/graemlins/grin.gif
    As for the question of should they have been replaced.....YES.
    Do most places do it.......NO.
    The sad part is the seals are cheap and a PITA to get to, so when the carrier and axles are out for a gear change, they should be redone (even if only a few hundred miles on them). When you change them, you should be able to tell if the existing ones are new or not (or if they were installed incorrectly....mishapen from being hit too hard/incorrectly).
    Good luck.
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so it all has to come out?? that sucks....it's only leaking at the very end....
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> But the seal is in the center section, just outboard of the carrier bearing. </font>
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    that's just great....
  12. Toledo
    Toledo 1/2 ton status
    Dec 10, 2001
    207
    College Station, TX--DeRidder, LA
  13. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Two words:
    Expanding Foam
    /forums/images/graemlins/thumb.gif
  14. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Two words:
    Expanding Foam
    that is seriously tempting...
  15. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> How about propshaft packing? /forums/images/graemlins/thumb.gif </font>
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Getting to the seals is not that bad, getting them out is a major PIA without a seal puller, minor PIA with. I replaced both of mine not too long ago. Pull axles out, pull the carrier out, pull seals out, replace...
  17. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    GM part number is 462857. Got mine thru local GM dealer.
