Problems with the Pro Jection instalation: Help and suggestings needed!
Discussion in 'The Garage' started by zakk, Feb 9, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    OK, today i sat down and started detailing the instal I need to have done by Feb. 28. I have a few off days mixed in there, so I think it is possible.
    There are two wires that I have NO idea what they do. they are both on the "Power" side of the wiring diagram.
    Problem #1
    This wire is part of the main harness, and is spliced into a gree wire. I already had the wiring done on the fuel pump, what can this go to?
    Could it be a ground? Pic of the rear of the "power" harness:
    Problem #2
    I think this was added by the past owner. It is in the "green" wire (fuel pump) and splices into it. The past owner had a toggle switch to prime the TBI. Is that what this connection could be? I don't see it anywhere else in the manual.
    Thanks in advance! /forums/images/graemlins/thumb.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Which model do you have? I have the 2D installed and the 4Di system sitting on a shelve. I can go look at either one.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i have the 2D. sorry I didn't post that up!
  4. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Zakk, can you take a picture of the whole harness layed out
    so I can see all of the wires. Hook up all of the connectors to the throttle body and then I think I can help you. The brown wire looks like the one I spliced to the toggle switch. The green wire I am not sure about. If I see the whole picture I can help you out. I am pretty sure I had that hooked to ground.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    last night a read over the manual a few more times after I talked to you and there is a sentane that states:
    "The stand alone black wire is the ground for the 'power' harness..."
    looking over the wiring diagram again, there is one back wire off of the power harness that doesn't go to the female connector, so i am sure it is the main system ground.
    Thanks! /forums/images/graemlins/thumb.gif
  6. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Cool hope it all works out for you, you have my number if
    you need any more help. /forums/images/graemlins/thumb.gif
