Problems with the slip going back into the NP208.....NEED HELP ASAP PLEASE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, Jul 25, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Trying to put this truck back together and i am on the rear dive shaft. I think i have the wrong one, but at the same time i think its to short for much else. What are the # of splines. I didnt see a key. This is going to be my DD so i need it going soon. thanks guys
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Should be 32 spline output without a keyway. Make sure the yoke end is going in straight and it should slide right in. /forums/images/graemlins/dunno.gif
    Maybe check the driveshaft end for any damage or burr's at the splines. The tiniest burr will keep it from going in.
    Rene
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    No key, no master spline, so it should slide in with a couple gentle twists to line the splines up. I put a bit of grease inside the output seal, and a light coat of ATF on the shaft, to help lube the slip area and avoid tearing or gouging the seal.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    It was a bur. thanks guys /forums/images/graemlins/waytogo.gif
