PROBLEMS
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TED, Dec 2, 2002.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    My Blazer started running like crap, so after checking the timing I pulled the distributor cap and rotor. My mechanical advance weights were overlapping. One was up on the other but the springs were still attached. After fixing this problem I ran it and it was fine, the power was back. I went to tighten the distributor hold down and I was about to shut the hood when I heard it lose about 200 rpms and i also heard a clicking noise. Right away i noticed that the #6 wire had melted to my exhaust manifold and was now arcing to it. Looks like new wires for Christmas. Anyway, I pulled the wire away and covered it with electrical tape. The next time I drove it it was running crappy about a mile down the road. I checked the wire and it wasn't arcing to the manifold, gotta be the mechanical advance weights again. How do I prevent this problem? If it's not one thing, it's another.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can buy rebuild kits for the distributer that come with different springs and stuff from summit. If you don't want to do that now might be a perfect time to swap in a HEI.
  3. TED
    Nov 27, 2002
    81
    San Jose, CA
    Yeah, maybe I should get my Summit magazine out. The distributor I have now is an HEI.
  4. ChevyDrivnRdneck
    ChevyDrivnRdneck 1/2 ton status
    Nov 25, 2002
    714
    Modesto, Ca
    I may have an extra HEI laying in the garage....... /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  5. ChevyDrivnRdneck
    Nov 25, 2002
    714
    Modesto, Ca
    Sorry man all I had was a points distributor /forums/images/graemlins/crazy.gif I do that have that and wires too for both kinds...points and HEI /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    junkyard and hei. i got mine for 5 bucks.
  7. TED
    Nov 27, 2002
    81
    San Jose, CA
    Thanks guys, but as I mentioned I already have an HEI in it. I don't want to swap in another one if I can make a quick fix on the one that's already in there.
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I was having the same problem.The Kragens here sells recurve kits for $8.It comes with all new mechanical advance parts.The center piece,weights,the plastic bushings the weights pivot on,and new springs. /forums/images/graemlins/grin.gif
  9. TED
    Nov 27, 2002
    81
    San Jose, CA
    Thank you Frizzlefry, all I gotta do now is find someone that will paint it for me as a Christmas present.
