probs accelerating & high speed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77Blazer, Aug 21, 2001.
  1. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    first off i put on some engine mods recently dual exhaust (flowmaster) hedman torque step hedders, holley manifold, k&n airfilter and rebuilt my carb.
    When i mash the pedal it stalls out (this was b4 all the mods as well) and when i got up to 65 it feels like its not getting enough gas and it slows down to almost 40 b4 i can put my foot on the pedal and have it accelerate it again but I have Gobs & Gobs of accelration power from 20-65mph.
    350, sm465, NP205, 14 Bolt w/Detroit locker(465 ratio), Dana 60 465, 38.5 swampers
  2. dyeager535
    26,975
    Does the "stall out" occur even in neutral when you floor it? Backfiring perhaps? If yes, try sticking a dime under teh accelerator pump lever and seeing if that makes a difference as you hit the accelerator linkage (dime usually won't stay by itself, it doesn't fit very well) Easy test of the accelerator pump/arm.
    As to the 65, well, thats easy. Go 65 or slower : )
    Just kidding though...if you get to that speed, do you get a bucking sensation? How about trying to hold the truck at a high RPM, NOT trying to accelerate up a large hill. Just try holding a steady speed at a good RPM. You don't want to be into the throttle a whole lot at this time. Then, after holding that speed for a few seconds, leaving it in the same gear, floor it. See if it starts to buck and lose power. Going to update my post, but mine did the above, and it apparently was a malfunctioning fuel pump. Could just as easily be plugs, wires, fuel filter, you name it, but I knew my other stuff was good, and the fuel pump was old, and under warranty anyway : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like its time to replace your fuel filter. A clogged filter will do just what you are describing. Replace it before you try anything else. It's cheap and easy to do.
  4. AntAZBlaz
    AntAZBlaz 1/2 ton status
    273
    Mesa AZ
    Hey
    I have the same issues that you were having, I went on a camping trip and as I was cruising around 65 and some times when I would try to pass some one I would lose power or it would not have any acceleration if I kept my foot on it I would get a surge of power. I replaced my PCV valve, I recently changed the fuel pump, and I replaced my spark plugs. I still ended up with the surging problem and loss of power. From what I read I think that there is an air leak somewhere. If anyone has any info on how to trouble shoot any farther please let me know.
    Anthony
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If you think you've got a vacuum leak, take a propane torch (unlit), with the valve only slightly cracked, and run the tip around any potential leak sources - the motor will idle up whenever you come across a leak.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Had the exact same problem about a month ago. Very frustrating to try and nail it down, but I finally figured out that the secondaries were not opening. Plus the carb was in desperate need of a rebuild. So I rebuilt it myself, replaced a bunch of pcv and vac lines, then spent about a week dialing the carb in (tor the air horn off to adjust the float level and power valve about 6 times). Overall it was a great learning experience and was never without an operating vehicle.[​IMG]
    James
    79jimmy@home.com
  7. 77Blazer
    Aug 13, 2001
    197
    Long beach CA
    thanks for all the input guys im tearing into it on thursday wish me luck!
  8. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Fuel filter!!!!!!!!! Just went throu all this stuff over a 9 dollar filter.
    You call that dirty!?
  9. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I'd say fuel filter to the person with the passing situation and then surge on power....i've had three old chevy's now and thats the first place i check for acceleration problems...i know they are only in need of changing every 25,000miles but i change mine about every 5 just cuz running a tank below a 1/4 tank usually starts sucking any junk out of the tank that is present....other than that vacum leak...but definatley check the fuel filter first, and carry extra's! they are only what $1.99?
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
