Progress Report
Discussion in 'The Garage' started by 79Stomper, Jan 2, 2005.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Well started out to be a good day but ended in a few problems. First lets take a look and see how she has turned out with the axle swap, beadlocks and tires.
    Well tried to attach pics but file is too largeand gallery is down. The more I play with this board the more I hate it.
    Anyways, got most of the small stuff done like vent tubes for pumpkins, steering stabilzers on, pumpkins filled with gear oil etc. etc.
    Went to put the rear driveshaft to the pumpkin and ended up breaking a bolt off in the yoke so now have to order a new set of the U-Bolt type straps to hold the U-Joint on the yoke. Well went to fire it up and straighten the wheels and well couldn't get the key to turn over, tried a little bit of muscle but didn't budge plus I didn't want to screw up the column. So I commence to take apart the column and got that all straightened out in there. It was just binding up with the pin in the wheel .
    While doing the vent tube in the front I noticed that my engine crossmember is cracked. So there will be another project when I pull the motor out in a month or so. Anyone know of any company that makes new crossmembers?
    Check out the link below for pics.
    Here is a link to a site that doesn't restrict file size. http://www.nc4x4.com/messageboard/viewtopic.php?p=102715#102715
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Man, that thing is looking good!! :saweet:
    You had mentioned it sagged in the rear but it looks level in the pics, did you do something else to it? If it's an illusion, what did you decide to do, add-a-leaf or flip?
  3. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
  4. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I didn't do anything. I think I was just looking at the wheel wells and not the body line. May sag a little bit, (1/2"), but not very much. Not going to really worry about it anymore. Have alot more to do in the coming months before my trip to Tellico.
  5. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Nice Job!
    I didn't see anything in LMC, you might want to call them 1-800-541-8525.
  6. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Damn I must say, that thing looks great!!! :cool1:
  7. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    sweet rig :bow:
  8. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Thanks for reminding me about that. Should fix it right up and handle the semi new motor.
  9. ryoken
    Jun 13, 2003
    29,622
    1,373
    Jersey Shore
    no prob.. i've eyeballed it a few times..
    may consider it when i do my thorleys... be nice to have it "cleaned up" down there already when i figure out what i'm doing with susp/x-over, etc...
  10. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Just FYI, I noticed that UAO85 has an engine crossmember for sale (CHEAP) -
    http://coloradok5.com/forums/showthread.php?p=1103588#post1103588
    Edit: I just looked at your pics again and that thing looks SAWEEEEET!! :saweet: :bow:
