Progress??
Discussion in 'The Garage' started by mountainexplorer, Jul 21, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Not sure if I should call this progress, but the front axle is bolted under it and it's on two tires instead of blocks.
    I tore it all apart in 2001 and it's had 2 front ends under it since and two pairs of leaf springs. I'm going to try and continue assembly this time and not change my mind again.
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    awsome
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,022
    849
    Pinckney, MI
    Good work, but seriously Alan if you have too many things to do, I could take one off your hands for next to nothing :rolleyes:
  4. mountainexplorer
    Nov 14, 2001
    4,903
    Nah... I'll get it done this year. Doesn't need much. Just needs the rear shackle flip bolted in, rear axle bolted into place, throwout bearing sleeve put in the tranny, front yoke on the T-case, motor mounts, steering box, repair a crack in the frame, put a motor in it, bolt the nose clip and bumper on, mount the winch, and put in the roll cage. Thats a small list compared to some of the other projects laying around the place.
  5. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    what are the specs on it currently?
  6. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    thats how it looks now? looks like progress since I've seen it last...
  7. mountainexplorer
    Nov 14, 2001
    4,903
    Current specs? 1976 K5 Blazer painted camo with 465/205 and a Dana 60 front with 4.88 gears and welded carrier/spiders, 6" lift springs and aftermarket extended shackles.
    Rear will be a 2" add-a-leaf in with the original spring pack from my truck Blazer (under it now) and a shackle flip, a 14-bolt with 4.88s either welded or with a Detroit, and probably a 454 or maybe a 402 big block. Oh, and a Warn 8274 winch.
