Project "8 ball" Street legal
Discussion in 'The Garage' started by Quackaddict, Aug 20, 2006.
  1. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    Well after 5 months she is put together and street legal. Still seems like there is an endless list of small things to do but she is a driver now. Sanded down all the surface rust spots and got ambitious so insted of white with primer spots I painted it for $20 myself. Didn't want to go rattle can so I went another route...(shall remain nameless for flaming sake.)
    Gay project name but when I got done my wife said it looked like an 8 ball with the black truck and white top (waiting on $$$ for soft top) so she got me an 8 ball shifter knob and key chain.
    Also I am still painting the side moldings.
    before
    after
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Looks good! Your un-named paint source did a pretty decent job from what I can tell.
  3. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    damn yer truck looks pretty good! U roller the paint on? it looks good.
  4. Quackaddict
    Apr 2, 2006
    160
    ok so yes this is embarrassing. I had bought a gravity fed spray gun at a garage sale a while back and have been itching to use it. So spray paint would have cost me about $40 and I wanted to use my gun so I used rustoleum paint for metal and painted surfaces. I did some decent prep work. The pic is kinda far way so you can tell.
    It covered very well and from what I can tell is very strong not goona chip or scratch very easy BUT there are several areas that didn't come out smoot and are kind of textured and some look real good. This was my first time ever with a spray gun in my hand and I was experementing with thinning the paint as well.
    All in all for what it is I am very pleased, it was cheap, I did it my self and it should hold up well especially off road.
    Flame away
  5. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    It looks more like an old-school K-9 vehicle, back when cop cars were mostly B&W (instead of foppy colors like pastel blue and white).
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    looks good
    so what are the specs, and what was done to get to the after?
  7. Quackaddict
    Apr 2, 2006
    160
    well the before truck was a completly stock 80 K5. The only thing the PO did was take out the stock 305 and put a rebuilt 350 with a cam upgrade (good decision) Then it has sat for the last 3 years. (suprisingly all I did was change fluids,plugs, wires, battery, alternator, belts and starter and it has run great.
    I took out the 1/2 ton 12bolt and 10bolt with 3:08 gears and put in a 3/4 ton 14bolt SF with gov bomb and a 10blt both with 4:10's. Got a set H1 wheels and tires and took the rims off and put on black rockcrawlers. Then put on a 6" RC lift and zero rate. Did the brake lines and all new fluids. I also added an Edelbrock Air-Gap intake manifold. Then shot her black and painted the trim red.
    Also added the ever important "8 ball" shift knob and skull T-case shift knob. I also have a set of Triple gauges to install to track all my temps better.
    Needs:
    Extended driveshafts
    Fix speedometer
    Rear main seal for tranny.
    Tranny Cooler
    Wants:
    Heavy front bumper with winch
    Boggers or IROKS
    stereo
    Cowl Hood
    better interior.
  8. NoReGrEtS
    Nov 7, 2005
    848
    how did your drive shaft angles come out?
  9. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    Looks good.
  10. Quackaddict
    Apr 2, 2006
    160
    They are ok need to get the shaft lenthened. Back is pretty good front will do but could be a little better.
  11. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks good
