Project Cheap Bumper Update mini sliders.
Discussion in 'The Garage' started by MTBLAZER89, Jun 15, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The build of my cheap bumper is here. I wanted to trim the lower quarters behind the rear tire and after I did it it seemed like a nice spot for a little body protection. Prolly around $15 dollars for this addition. So I believe I am up to $80 on this project.
    Cut
    Sliders
    Pass side
    Driver side
    They came out ok. I still have to remove the bumper so I can weld up the rest and put a brace on the inside for side impact. I am not sure if I like how they flow with the bumper, but they'll prolly look better with paint. They are functional though right.:D
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Nice :waytogo: The good spot for the brace to the side is right next to the spring hanger . Mine was done so the kicker from the bumper to the frame has a break in it with bolts , so bumper can be removed if need be .
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    nice, i want to to trim and add stuff like that soon!
  4. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    That is perfect and looks great:waytogo:. I might have to borrow that and do it to mine:whistle: :thinking: . Hey pauly do you have pics of your brace I just can pictur what you are saying.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes I do . This is how Matt ( az-k5 ) designed it . It ties the side of the bumper to the frame in front of the hanger :D
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    That cheap bumper just gets better and better.
  7. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I think it turned out pretty good. I like it.
  8. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    good job on the bumper. I'll have to check it out at blazer fest :D
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well I don't have the materials to make the brace like paulys. I do however have some 1.25 tube that I am planning on running from the forward end of the slider back at an angle to the bumper mounting bracket. That should work for now.
  10. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I think that part #00117 http://diy4x.com/misc.htm or something of the like would work well with the 1.25" tube you've got to do it like Pauly's. I think it would be stronger to tie it in by the hanger than back to the bumper itself. :dunno: I would go with the non-shear type, but then you wouldn't be able to slide it backwards.
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Those look cool . And this way you can also high lift from the side with no flex from that tube .
