project ideas?
Discussion in 'The Garage' started by MTChevy, Apr 3, 2007.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    I am currently in the chassis fabrication/high performance class in Wyotech. We can do a project. I would like to do something on one of my rigs at home but i found one here. its a 78 suburban... I need help generating ideas on what i could do for a project. things range from cages, to 4 links, to high perf. engines... suggestions?
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Take all the sheet metal off it and cage it!
  3. pin_it_to_win_it
    pin_it_to_win_it Registered Member
    Jun 21, 2006
    94
    centeral coast california
    cage it, put a bad a$$ motor in it and make it tall enough to run those new 54" super swamper boggers!
  4. pennsylvaniaboy
    pennsylvaniaboy 1/2 ton status
    Jan 28, 2006
    844
    pennsylvania, 15537
    make an avalanche, no doors, ,cut the back top off, cut the bottom of bak of bed off trim fenders, build som awesoem bumpers, ,cage it and build a crazy motor, put on some rocks, the possibilites are endless
  5. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Well I will let you in on a little secret project I have been planning. Build a custom frame, round tube/rectangular tube/ or combo of both. Then narrow the entire body down the middle. Take several inches out maybe a foot or so. Using a burban body this will be a two seater, passanger sits behind driver
    Then you can chop some of the top if you want to or bob the rear and put 1-tons in it :D .
    Here's a pic of this done to a truck ignore the ugly a$$ bumpers
