Project Update!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blaze, Jul 6, 2000.
  1. 85blaze
    85blaze 1/2 ton status
    Feb 20, 2000
    117
    Corning NY
    Just thought I would post an update of what seems to be the never ending project K5. And yes I know I haven't posted since like april. Its almost all skinned and no more rust showing, Still need to do a lot of work, But now im keeping the K5 whens its done due to an improved finacial situation. Anyways, now for the question, I am building up a motor for it, but donno if i should go with a 400 or a 350. The 350 has a lightwieght rods, pistons etc.. and could turn 7,000 all day, the 400 is more of a stocker motor, balanced and blueprinted, but not as built. Either motor is going to have a set of Double Humps on it and probably an edelbrock or similar aluminum manifold.. Suggestions? I will post some pics on the "sliver bullet" in the primer/bondo/multi color stage in a while.
    Blaze On ----- into the $$$ pit! Dang these things can cost ya alot!
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Double Humps? What are you doing to that thing!?
  4. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I think the 400 would be better. everyone has a 350...so everyone has parts, but 400 has more power...
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
  5. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    I'd personally go with the 350 all day long. Shorter stroke, more water jacket volume, stronger webbing between cyl., and it sounds like a lot of the weaker factory parts have already been replaced. Since you said the 400's mostly stock, the 350's probably putting out far better power anyway. $.02 [​IMG]
    <font color=blue>~BigBurban</font color=blue>
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Go with the 350, you can buy parts for it at 7-11 or Piggly Wiggly.
    YEEEEE HAWWWWW[​IMG]
  7. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    I say 400!!. Build it yourself if you aint happy with its performance, you already got good heads (which usually is the most expensive item by far). Just don´t forget to drill steamholes in the heads if you go with the 400, ok?[​IMG]. Almost everything you can throw at a 350 you can throw at a 400 too!! Btw, did you know GM´s HO 502 big block also has siamese forged cylinders?? Bigger bore & longer stroke equals bigger smile on your face[​IMG]
    Andreas
    406cui of pure sh*t[​IMG]
  8. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    Don't forget the old hotrodder's saying:
    "You can't beat cubic inches."
    Also don't forget the classic from Road Warrior:
    "Speed is just a matter of money. How fast do you want to spend?"
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's
  9. 85blaze
    Feb 20, 2000
    117
    Corning NY
    Im just making to go a little faster :) and alittle more power
  10. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I say it depends on how many RPM's you want the engine to max out at. Because of the poor connecting rod angle of the 400, I would be afraid to build it as a high RPM motor. So here:
    Rockcrawling: 400
    Mudrunning: 350
    Thats what I think.
    '73 K5
    Chevy good...Ford bad
