projected redline on 350?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77K5Blazer, May 25, 2001.
  1. 77K5Blazer
    77K5Blazer 1/2 ton status
    Mar 11, 2001
    255
    Hood River, Oregon
    All right, what is can I safely consider the redline on my '89 carbed GM 350 crate to be? My dad says that it is 3,000 rpms, but that sounds a little low, what can I run it to, without any worries? Thanks a lot!
    1977 Blazer, GM350, SM465, NP205, Dana 44/ 12bolt, 31x10.50r15 BFGs
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think its 4500 to 5500, something like that....not much power up there anyway.
    90K5
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Your Dad's telling you 3000. So you don't redline it and he as to buy you a new motor......LOL
  4. 77K5Blazer
    Mar 11, 2001
    255
    Hood River, Oregon
    Yeah right, I wouldn't want my dad to buy me a new motor! I am proud to say that I worked my A$$ off for 3 years to earn the money to buy my K5, and I love it! I don't want to blow up my motor, cause if I had to put a new one in, I would want a 454 WAY to badly, and I can't afford that!
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I dont know what crate engine you are running but my 350HO is listed as a 5500 RPM redline...The ZZ4 is like 5700
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  6. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Max RPM's is relative to how much money you have to spend. If you have a lot, take it to 55-5700 frequently, if you want to keep your money for better investments then new engines, consider 5000 max and even 45-4800 for best use of the torque curve that most crate engines like the 300 or 330hp versions. I run a pro-built engine that saw 5800 on the dyno during break in but has never seen over 4800 running in the truck. They just plain cost too much.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  7. 77K5Blazer
    Mar 11, 2001
    255
    Hood River, Oregon
    Next question...it is completely stock and I don't know what model it is, I know that it is an 89 GM 350 crate motor, so how do I find out what the estimated horsepower is?
    Steve Fox for US president!!
  8. Storm Trooper
    Nov 24, 2000
    4,640
    My 350Ho is 5500 - 5800 safe max.
    If it is a crate motor, there is a tag on the pasenger side of the block in the middle, just above the motor mount. Check the numbers with your local GM dealer or try this
    <A target="_blank" HREF=http://www.gmgoodwrench.com/crate_engine/index.htm>http://www.gmgoodwrench.com/crate_engine/index.htm</A> I built a 327 along time ago that could handle 10,000. To bad I couldn't find a dist. that could. Good luck.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Redline? Just before the internal combustion engine becomes a external combustion engine, then back off the throttle.
    And duck for projectiles.
    Twiztid
  10. 77K5Blazer
    Mar 11, 2001
    255
    Hood River, Oregon
    Hahahaha....that is what I want to avoid if at all possible!! Don't want any projectiles other than mud flying from my tires!!
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Reminds me of when I asked the same question at an engine building shop. The guy looked at me with a straight face and said the only 100% safe RPM for any motor was 0. [​IMG]
    I actually would like to install a rev limiter on mine...the last time I was in the mud I glanced at the tach as it was coming down from 6000 RPM [​IMG]. Its too easy to get carried away!
    Normally my little 350 never goes over about 4000 RPM, even that is rare.
    Rene
    <font color=red>If at first you don't succeed...skydiving ain't for you!</font color=red>
  12. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Ohh boy, could I show you some reel distruction!
    Chunks of unidentifiable parts, rods hanging ot the side of a block, hydo locked blown and injected engine (bent the aluminum rod up like V and twisted it), BIG holes in the side of a block you could fit your fist in! A rod hanging out the bottom of a LS7 454 chevel's oil pan.
    I've been saveing some of the parts, and I'm going to hang them on "the wall of devistation" in the garage.
    Twiztid
