Prop Valve
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bobsurf, Jun 26, 2001.
  1. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    It appears that the proportioning valve is shot on my 73 Blazer. I can't properly bleed / fix the brakes without this. The button on the end of it appears to be stuck in. Any ideas on fixing/replacing? Dealer part is $180. Can I use one off a different year (73-85)? Thanks
    Newbie, 73 Blazer project
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm sure you can granted that the truck you take it from has the same brakes, as in, same caliper size and same rear wheel cylinders. It all must be matched.
    Tim
  3. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I have one off a 73 (frame mount) that is in great condition. I will let you have it for one can of cheap beer:)
    harry
    69K5
  4. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    Harry, I've seen some of you work before. Maybe worth a can of Natty Ice at best. Besides, the last time I helped you out, you left me 10 square feet of Brake fluid stains on the driveway, or was that me ..........??????
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    One from another year will work. But lines may exit/enter in a different location. The prop valve for my 78 k10 was 75.00 fron chevy dealer.
  6. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    Could anyone explain the inputs and outputs for this prop valve I have one to install from scratch. Thanks
    Lukers
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  7. bobsurf
    Jun 26, 2001
    410
    San Marcos, CA
    The in and outs for a Prop valve are pretty straight forward. If you have your book it should explain it. Basically just a Front and Rear "in", and a Front and Rear "out". It's just a matter of which one is which.
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Two lines in from master cylinder, front and rear. Three lines out. Front left, right, and rear. The end with the 'button' on it is for the fronts. Where the brake light switch is where the front and rear are seperated.
  9. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If you ever plan to upgrade the brakes, such as 14 bolt rear drums, or 4 wheel disk, now would be a good time to upgrade to an adjustable proportioning valve, about $40 from Summit.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  10. lukerz
    Apr 13, 2001
    109
    Western Mass
    Thanks I have ordered a do it yourself kit from inlinetube. Great help. I got tranny and fuel lines too>
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
