Propane injection
Discussion in 'The Garage' started by fulltopblazer, Oct 18, 2002.
  1. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I've been thinking of going to propane injection on my blazer. I think it would be cheaper than buying a EFI system. But where could I mount the tank? I don't want to put it inside because it stinks and....well...its flammable. Does anyone have any suggestions or is anyone running propane on their rigs? pros and cons please.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Propane with gas engine or diesel?
    I am putting mine under, if you look down there there is plenty of room.
    Mine is for diesel though, it's like nitrous for gas.
  3. fulltopblazer
    Aug 1, 2001
    484
    mine is gas, where at under? Mine is a full top blazer so it has the big supports under each side behind the rockers.
  4. fulltopblazer
    Aug 1, 2001
    484
  5. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    Why do you want propane? For a Diesel, it's considered a "poor man's turbo" as it really boosts the power. But for gas engines, the energy to cost raio is less than that for gasoline due to therising costs of propane. So your truck would have less power wth equal amounts of fuel. If you want the "injection" aspect, go to swap meets and look for the older Holley pro-jections. They're around $350 in the NW. But the Q-jet really can be tuned in to perform on and off road. Next to the Motorcraft 2 barrel, it's the best carb for inclines due to float bowl design.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a manifold tank will go where your existing fuel tank is
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
