Propane injection
Discussion in 'The Garage' started by mud390, Aug 23, 2003.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    What are the benefits of this setup? I understand the basic concept, but not the gains of it. It seems like you wouldn't be able to have a "performance motor" running on propane. The whole 100lb tank in the back kinda scares me too, but thats a different issue. What kind of fuel economy would you expect? Power? Drivabality? Thanks!
    Kris
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Propane injection is found in diesels, to suppllemt for power and mileage.
    Propane injection is not found in gas engines. A chev 350 for example, is run strictly on propane or gasoline, or with the option to run either at the flick of a switch, called dual fuel.
  3. mud390
    Oct 31, 2002
    1,210
    How does it do for performance and drivabliity? What about the feasability and simplicity of the whole setup?
    Kris
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    incredibly simple and reliable
    higher octane rating then gas 100+ IIRC
    you can get the good stuff used/rebuilt for $400 for the engine side buit have to get your own tanks etc
    you want an OHG mixer!
    I havent dealt with this local guy but he has a good simple website
    http://www.propaneguy.com/
    if you deal with him and there are 'issues' I am close enough to knock on his door if required.
    downfalls of propane:
    -doesnt like extreme cold
    -availability, here there are many filling stations
    I have a friend that is alt fuel certified and did many big block dual mixer installs
    his boss had a 500", dual mixer, turbocharged, C6 gearvendored, lincoln.
    he did real sweet looking installs (unlike most shops) so I could try and get details from him for making it look clean and pro,
