Propane tanks as air storage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Aug 30, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I have a bunch of old forktruck propane tanks at work that we cannot get filled anymore. I was looking at one today and thought it would be a ducky compressed air storage tank. I know propane is stored at a low pressure (40 lbs?) since it is a liquid. Anyone ever think of converting one to air storage?
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If they're too unsafe to put propane in, they're way too unsafe to put air in at high pressure.
    Tim
  3. Cavalry
    Oct 1, 2000
    978
    They are in pretty good shape. There is a "life expencatancy" to a propane tank regardless of its condition, after its time is up (determinied by the stamped year) they will not refill it regardless of condition.
    Luke
    84 K5
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Have you heard about re-ceritification ?
    Some say it can be done for less than 8 dollars !
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes! Use them!Propane tanks are pressure tested to three times their rating for certification. Air is not combustible, so go right ahead. Have you ever seen an expiry date on an air tank?
    My uncle uses a pair of expired forktruck tanks for his home-built compressor. Another fellow at the shop uses an expired 60-gallon one together with 20-gallon compressor for extra reserve.
    Only thing is your air tools will smell like propane for a while. Yuk!
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    There is a test/expiration date on air tanks, but for non-commercial use it's pretty hard to enforce.
    If the shoe fits, get another one just like it
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
