propane
Discussion in 'The Garage' started by 85gmcOD, Nov 6, 2006.
  1. 85gmcOD
    85gmcOD Registered Member
    Jan 24, 2006
    62
    greentown, pa
    ive got a project truck that i keep getting more involved with as i go.. i was reading about propane and its a pressurized gas.. this means u can run a carburated engine at any angle.. i think... i probably gonna be gettin a motor for my truck sometime soon and was thinking of some type of fuel ingection but its real costly and the wiring can be a killer on the trail.. to get to the point i was wondering if anyone is runnin propane?? what ar some of the pros and cons of this setup... tanks, lines anything and everything would be a great help thanks..
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    search man there is a ton of info on this site about this.
  3. 85gmcOD
    Jan 24, 2006
    62
    greentown, pa
    alrite thanks
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    there are some drawbacks. the guys I wheel with run "pane" as they call it. They run forklift bottles and will run out on a full day of wheeling. they shut it off everytime they come to a stop. It doesn't work with a normal gas carb. you have to get a completely new setup, unless you are talking about a blended system.
    The truck would run upside down if the oil in the crank didn't have something to say.
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    Pros:
    Super simple (no wiring, fuel pump, IAC, TPS, etc to fail)
    Propane is cheap
    Propane burns very clean so your oil doesn't get nearly as dirty
    Runs at any angle
    Cons:
    Propane is tough to find
    The most common (read: cheapest) tanks are small (~7 gallons)
    Slightly worse mileage and power (if you keep a gas compression ratio)
  6. 85gmcOD
    Jan 24, 2006
    62
    greentown, pa
    thanks for the input... im buiolding the motor some time in the future and would proabaly go full propane i dont think i would go dual fuel... and would the junkyards be the best place to find those huge propane tanks... 100lbs or so =...
  7. nschingeck
    nschingeck Registered Member
    Jul 12, 2006
    23
    Colorado
    You can find 100lb propane tanks at Home Depot there around $100
  8. 85gmcOD
    Jan 24, 2006
    62
    greentown, pa
    no ****.... thanks i havent looked around much yet becuse i dont have the new motor built yet... would that tank be suitable for the truck and can it take some abuse... if u have any idea... u never know whats gonna happen..
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    sorry for the hijack but what about running propane on a dd? Im fixin to start a new project and will be building a motor for it. I already know quite a bit about it and would like to build my new motor specifically for propane. There are at least 2 filling stations in my home town and I could get a tank large enough to last me a couple of weeks so how practical do you think it would be? would it be a bad idea? I would prefer to stay away from a dual fuel setup if I could.
  10. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    especially with a big tank, i see it being perfectly practical. weigh your options though. propane is great, but it is possible to do EFI cheap as well.
  11. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    the tank on up in the back of my truck there is 100 gallons. at 80% legal fill capacity, you're getting roughly 80 gallons of fuel. it used to run this truck in stock trim around everyday daily driving for about 2 weeks (350 sm465)
    that tank fits perfectly in the bed of a pickup.
  12. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    how do you fill it? most of the places aroung here have their tanks fenced in making them hard to get close to with a truck.
    I used to work at a gas station where we filled tanks. we would weigh them on a scale to make sure they were full but not overfilled.
  13. 85gmcOD
    Jan 24, 2006
    62
    greentown, pa
    the tank does fit very nicely right behind the cab... its definatley a possibliity for the new motor... would it burn about the same amount of gas u say or a little better.. even in a 454??? i just realyy like the fact its like a cheap efi and u can run any angle.. but u still ahve to watch ur oil and such.... and can u tell ur runnin pane by a different sound or smell..
  14. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    sound isn't different enough to be noted, smells like a bbq grill lol
  15. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i've read you only lose about 1/10 per gal on propane, gas 10/10 a gal,(10/10 being what ever your mpg is) propane 9/10 per gal. a lose of 1/10,was told this by some1 running propane. i'm thinking of going to propane but cant find any place to buy new mixers to replace my carb, and i've googled it all the ways i can think of, i found tanks that will fit where your stock gas tank is but can't find the rest of the system! any1 know the best place to get the stuff for the swap?
  16. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
  17. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    you need Impco propane components.........as far as I've seen...by FAR the most common propane components availiable.......for cars trucks busses forklifts, zoombooms, genies.....anything that'll burn LPG
    My truck has
    Mixer- Impco 425
    lockoff- VFF30
    converter- Model J
    http://www.impco.ws/
    I'm pretty sure about the last 2......its been so long since I actually looked at them. around here go to the junk yard and you;re tripping over the stuff...... all pieces have overhaul kits availiable.......cheap and easy to do yourself.
  18. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You need a model E regulator.
    For the lock off you can either use the vff30 which is a automatic type lock off or you can go electric which uses a switch to controll the shut off.
  19. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    model E ........that sounds so much more correct
  20. suicide jockey
    suicide jockey Registered Member
    Oct 29, 2006
    18
    Texas
    Lp
    Parts for Sale- naughty naughty!!!! :shame:
