Proper fluid for NP205.
Discussion in 'The Garage' started by trailblazr81, Aug 3, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    So I just started to hear a slight whine from the T-Case in my 73K20. Figured I would pick up some fluid after work on the way home. I dont trust any of the guys at Kragen or Autozone around here since all they know is how to push keys on a computer. Whats the proper "oil" to use in a NP205? It usually leaves a couple small drips on my driveway.
  2. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    80-90W, Approx 4 quarts to the fill plug.
  3. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I pulled a '205 out of a Ford once, it had ATF in it. Also my ex-air force '88 crewcab had ATF in it when I got it. Switched it over to synthetic 75w-90.
  4. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    depends if it is leaked into by an auto or a stick tranny. if auto atf if stick 80/90. if no leaks then 80/90 for sure :dunno:
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Newer 205's use ATF if you can believe it...although I'm not sure exactly when that started I'm guessing it was the mid 80's.
    Rene
  6. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Yup, my '88 was filled with atf. We never changed any seals and have never added any fluid to the trans in over 4 years.
