Proper Lug Nut Size
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by backlash, Oct 29, 2002.
  1. backlash
    backlash 1/2 ton status
    Oct 21, 2000
    519
    Northern, VA.
    Bought a set of Ultra Wheel 164's and the lug nut heads appear to be too large or the nuts themselves are too short. The nuts only stick out from the surface of the face of the rims less than 1/2". I could not get a decent bite using a 4-way lug tool. I guess a thin walled chrome socket would work, but if I ever get a flat on the road or loan it to someone, or when I take it in for inspection every year, or rotate them ... someone will attempt to use a standard impact to remove the wheels and destroy the finish of the wheel or round off the lug heads.
    Anyone have these in 15x8" and can measure the lenght of the lug or the size of the head.
    Any suggestions? /forums/images/graemlins/confused.gif
    Thanks,
    Backlash Bob
  2. Grim-Reaper
    7,385
    Atlanta
    Proably could get a taller lug nut.
    You might try to grind the 4 way down to fit into the rim is the other thought. Problem is 4 ways are typically not the best metal and with thinner walls you might break the end.
  3. backlash
    Oct 21, 2000
    519
    Northern, VA.
    Grim,
    Thanks, but was wondering if that would even help ... a taller one would allow for an impact socket, but it would prolly rest on and scatch the face of the wheel.
    I have no problem with using a chromer when I work on it, but am just wondering about being on the road ... projecting, I guess.
    Anyone have these rims? I heard from Ultra that they do have a longer nut ...
    Is it worth the hassle?
    Thanks,
    Backlash
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    When my parents got new wheels on the 92 blazer we used to have they had a similar problem. My dad took one of the old lug nuts and welded it to the end of a deep socket. It worked good and now we use it on his jeep. Just keep it with your jack and/or lug wrench.
