proper shock length?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Apr 6, 2001.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    What is the best way to choose the proper shock length? I am finishing the installation of my 4" Skyjacker springs on my 78 and need to see if my existing shocks will work. I have measured between upper and lower shock mounts with the truck sitting level (just under 20"). I then used a floor jack to compress one side as far as I could and measured (just under 18" - I ran out of jack, but this should be close). With one side compressed, I then measured the other side (about 22"). These measurements are for the front only. Is this a good way to measure? The truck is not drivable yet because of rear 12-bolt problems, but I want to go ahead and finish the front.
    I seem to remember a website (Toyota related?) that had measurements for Rancho shocks. Does anyone happen to know the URL?
    DJ
    78 K5
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Well if you just want to run a "normal" sized shock, call the lift Mfg and ask what size they recommend..
    For a shock that gives you the best articulation, see if you can find somewhere that has a ramp(can you a sloped wall or something similar) on a forklift and take the same measurements that you did before.....
    Did you try using a block on top of you jack to get the axle/tire up higher?
    Not sure on the Toyota site..
    <font color=green><A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A></font color=green>[​IMG]
  3. djohnsn
    327
    Plano, Texas
    I found the page that I remembed - http://www.off-road.com/toyota/tech/shocks/
    I have the shocks that Rancho recommended for a 4" lift, but I don't believe that they extend far enough.
    I guess what I really need to know is if my way of measuring is reasonably accurate.
    DJ
    78 K5
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Sorry.
    Yes it is pretty accurate, but it would be best if you can get the springs to full compression and full droop to get a more accurate measurement....
