Proper TRE Torque?
Discussion in 'The Garage' started by mikey_d05, Mar 4, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    This is a really dumb question, but is there a torque spec for tie rod ends or just snug 'em down? Tried a search and came up with nothing. Thanks for any help.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    its very difficult to torque anything with a castle nut. Basically snug them down pretty good then put in the pin. I say its hard cause its not so common that when you hit the torque spec the holes line up with the openings.
  3. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks man, I was wondering if the pins were for overall safety or to keep the castle nut in place because you weren't supposed to torque them down real hard.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you want them tight, as with all fasteners, slop will cause wear and breakage.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If the TQ spec was written specifically for a castellated nut (which I have found is rare in automotive pubs), it will be a range, not a specific number; i.e. 67-112ft/lbs. You'd TQ to 67ft/lbs first and check the cotterpin hole. If it didn't align, you'd set the wrench for 112ft/lbs and turn the nut in small steps, until either the holes line up or you hit the TQ. If you hit the TQ and the holes don't line up, you could try putting a thin washer under the nut & retorque.
    If you find a number but not a range, you could add & subtract 10-15% from the number and make your own range. For example:
    Spec of 100ft/lbs. Add & subtract 15% and you'd have a range of 85-115ft/lbs.
