Proper way to bleed thats Power steering system......
Discussion in 'The Garage' started by Silver84k5, May 14, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    What i did was, with the front end jacked up i turned to lock one way and held it, then the other and held it, then put fluid in... so on and so on, I used abbout 1-3/4 quarts..
    I repeated this until the resivoir was full,
    Is there anything else i should do to bleed the air out? Thx.
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    NOPE! you did all you can /forums/images/graemlins/thumb.gif
  3. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeah, thats how i did mine, just cranked it lock to lock about 25 times, adding fluid as needed.
    j
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    k well i ony did it about three times, so ill give it another shot ;P thx.
  5. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    your on the right track, just keep doing it until you don't get any more bubbles and then your done.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If it starts to make a gnashing-grinding noise STOP turning the wheel. That is the sound of the pump cavitating. That does several things - all bad.
    Actually puts more air into the system (the physics of this are out there, take too long to explain it), and what fluid that is in there gets superheated which doesn't do any of the rubber in the system any good at all.
    If you stop turning and add fluid every time you start to hear that noise the bleeding will go faster.
