Proportioning Valve Customizing for 4 wheel disc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Sep 17, 2003.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I ran across a website last year that would customize the factory PV for disc brakes. Now I can't seem to find it. I'd prefer to go this route instead of with the Wilwood PV. Does anyone know what this site is?
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Inline Tube makes a disk-disk proportioning valve, its about the same price as the stocker disk-drum valve
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have the disk-disk proportioning valve from inline tube and it works great.
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Were all of the fittings the correct size? Which part # did you order?
  5. Grim-Reaper
    7,385
    Atlanta
  6. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    The fitting were correct, the part number is PR-101 $99
  7. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I actually bid on a Wilwood but I doubt it will last. Where did you mount yours at? Will the knob turn after time or is there a lock?
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Cool, thanks I'm going to look at it right now.
  9. Grim-Reaper
    7,385
    Atlanta
    Under the steering colum. Picture in that link I posted. Doesn't turn unless you adjust it. Nice and snug. Much higher quality peice then I was expecting for $50. It's race car quality stuff.
  10. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    The part number for the one from Inline Tube is PR-101. The cost is $99.00
  11. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sorry man your about 4 posts to late.
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Adjustable PV costs $50, need two lines for about $60 total if you can find somebody local to buy the Willwood from.
    Read the rest here.
    http://coloradok5.com/atrondiskbrakes.shtml
    summit has thiers, made by the same folks for 39 dollars.
    jst so yall know.
    Grant
  13. Grim-Reaper
    7,385
    Atlanta
    Read the rest here.
    jst so yall know.
    Grant
    Plus Shipping!
  14. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    you should go check this out...
    chevy part #1257225
    this is the proportioning valve chevy used on the 1-ton lunch trucks that had 4-wheel disk breaks, I went to a dealer by my work but they were to new to have all the parts yet...most dealers have the part so call and go check it out and see if it will work on are trucks... /forums/images/graemlins/thumb.gif
  15. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    chevy part #1257225
    Thanks, I'll check into that, the rest of my braking system is one ton so might as well go with a 1 ton PV.
  16. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Summitt doesn't charge shipping, or did they change that?
  17. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    They don't charge shipping but they do charge a handling fee.
