proportioning valve question
Discussion in 'The Garage' started by big83chevy4x4, Oct 7, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    putting brake lines on my buddies 81 4x4 3/4 ton truck, broke the fitting off at the hose, then the fitting broke off inside the proportioning valve on both front lines.
    are the 1/2 and 3/4 ton the same? are the 2wd and 4wd the same? i don;t have my LMC book here to verify. i know the yard has a 3/4 2wd and a few 1/2 ton 2wd and 1 1/2 ton 4wd truck.
  2. diesel4me
    Jul 24, 2003
    17,548
    938
    Massachussetts
    I'm not sure if they are internally the same,but I have used a proportioning valve on a 2wd truck on my 4x4 before--couldnt tell any difference.I'm not sure if the Hollander book they use at the junkyard will list just the valve--they list master cylinders and other parts,maybe they have a listing that could help.Now that I think about it,the valve on most older GM cars looks the same or very similar to the ones on my truck--my friend took the one off a 73 chevelle I bought for the motor for my van for his K5,he didnt say it didnt fit,so I assume it worked for him.The 1/2 ton and 3/4 ton ones look the same to me,might be different internally??.You cant get the broken fittings out with an E-Z out???. /forums/images/graemlins/dunno.gif
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i tried and ended up destrying the proprotioning valve. /forums/images/graemlins/doah.gif
    also, the junkyard that i go to doesn't have one of those hollander books, its my friends yard and i get parts cheap. /forums/images/graemlins/woot.gif
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Do yourself a favor and buy an adjustable proportioning valve, the better braking that will result is well worth it.
    Ken
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    well i would, but we are running out of money and it will take to long to get it. trying to get the truck going before sunday.
    anyway i got one from a 89 c30, it was the only one that he had that was the correct style. oh yea and free /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
