Proportioning valve
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 71WhiteBeast, Jun 26, 2003.
  1. 71WhiteBeast
    71WhiteBeast Registered Member
    Dec 11, 2001
    96
    San Carlos, California
    I have an 89 blazer with D60 and 14ff. I put some 35's on her(not sure if that matters), anyways she seems to nose dive now under hard braking. What kinda valve have you guys used to even out pressure to front and rear? Oh yea rear drum brakes! Thanks in advance!! /forums/images/graemlins/thumb.gif
  2. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    I cant speak for everyone, but after I upgraded to 37 inch tires the truck seemed to dive in the nose when I would brake. I think its because of the softer superlift springs and the longer lever that large tires create. If that makes sense.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Probably more the lift than anything else. Anyhow, I just used an adjustable valve plumbed in-line in the rear section. I can turn the knob and adjust it either way. I like to get it so the backs just lock up before the fronts, and back it off a wee-bit in the back to even it out.
    BlazerMan
  4. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ok, I just talked to an old chevy mechanic who lives down the street…was talking to him about the 14FF I someday will get hung on my truck and all the problems guys have with the brakes after doing the disk change over…He told me that the older motor homes had disk brakes on the rears and used a different proportioning valve then the trucks for the very reason we all see…he was not sure if the class was the k30 or k60 (I might be wrong here)…so if you go to a dealership and look through the older motor home you might find the answer…I'm headed that way tomorrow… /forums/images/graemlins/deal.gif
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    post up what you find out /forums/images/graemlins/thumb.gif
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    will do... /forums/images/graemlins/thumb.gif
  7. 71WhiteBeast
    Dec 11, 2001
    96
    What kind of valve did you use? Wilwood?
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that could be a recipe for disaster in the rain and snow when front traction and wieght transfer are reduced.
    I do not have a better recommendation
    brake proportioning setting is a very scary topic IMO
  9. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Well, you've got more sidewall now so it produces a better lever for the rear end to get "light." You can help fix it with some stiffer shocks.
    You can get an inline proportioning valve to limit fluid pressure to the rear brakes. I can lock up my rear drums easy with a stab of the brake pedal and I suspect it'll get worse when I switch to disks next week. I'll probably end up getting a knob or lever style proportioning valve from Summit. Wilwood makes Summit's so you might as well pay less for the Summit brand.
    EDIT:
    today is a bad punctuation day.
