Pros and cons of an add-a-leaf
Discussion in 'The Garage' started by cbbr, Jun 29, 2006.
  1. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have a shackle flip and a zero rate in the back. I need about 1" to level the Burb. What is the downside of an add-a-leaf?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    A little rougher ride and possibly a little less flex. With the weight of a 'Burb though, these won't be very noticable.
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Ditto. And if it's not a trail rig, then probably not an issue.
  4. 1-ton
    Apr 17, 2004
    2,890
    167
    Las Vegas, Nevada
    I have heard that an add-a-leaf can crack leaf springs, if you do a lot of flexing because when a thinner leaf spring wants to flex, the thick add-a-leaf does not.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Pro- cheap, easy to install
    Con- would probably limit flex.
    Is your zero being used to gain wheelbase? If not, then you *might* be better off going with a 2" block. That would net you the extra inch. That way you would only have a smaller chance of wheel hop, vs. stiffening the ride quality, or cracking a leaf. It's something to think about anyway.
  6. cbbr
    Jul 17, 2004
    14,681
    The zero rate is only there for the 1". I do drive it on the trails and that is why I have been building it. And I certainly don't need to crack a spring. The 2" zero rate may be a better idea until I break down and buy new springs.
  7. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    What size shackle do you have? if you have a 4" shackle, get a 6". Will be perfect to level it out. I run a 4" shackle flip, 6" shackle, and a zero rate for 6" of lift.
  8. cbbr
    Jul 17, 2004
    14,681
    ORD 4" flip. I hadn't thought of longer shackles, that sounds like a winner.
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    And you'll get more flex :D
  10. divorced
    Jul 20, 2004
    5,115
    Be sure it won't mess up your pinion angle.
  11. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Nothing a shim turned backwards cant fix IMO
