Pro's and Con's of the D44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaveBlazin, Oct 3, 2002.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Pro\'s and Con\'s of the D44
    Hey maybe yall can give me some pro's and con's of this 10 bolt. Ive been thinking about changing but I dont know to much about it.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: Pro\'s and Con\'s of the D44
    are you talking about going from a 10bolt to a dana44? if so it not worth it unless you are getting a 8 lug 44 and even then it is the same streangth of a half ton 44 just has 8lugs and bigger brakes
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    The last year for the D44 was 78 IIRC. The 30 spline 10 bolt is equally strong though so it's kind of a moot point. Both are good when used within their limits.
    Hey Spence I pulled this just double check myself, they are about the same, thats one of the reasons I never went to a 44 /forums/images/graemlins/usaflag.gif
  4. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    This was a commonly discussed issue on the board a year or more ago, but instead of re-hashing the pros and cons, (like pinion gear diameter, spline count, etc.) they are pretty equal. And by equal I mean so equal that there is really no reason to swap one for another unless it nets you something your axle doesn't have, i.e. lower gears, 8 lugs (to match a rear 14 FF), etc. I didn't even swap the axle when I went to 8 lug on my old k10, just swapped the outers from the 77 D44 on to my 10 bolt.
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Are the 14bolt and 10bolt rear ends the same width? If they are could you use a 8lug to 6 lug conversion to make up the width difference between the front and rear axles? What would the benifit or disadvantage of having the rear narrower than the front as many blazer are? I have always wondered that /forums/images/graemlins/confused.gif
