Pro's and Con's of the NP241 transfer case.
Discussion in 'The Garage' started by hawkeye649, Sep 27, 2004.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Pro\'s and Con\'s of the NP241 transfer case.
    I have a 1990 GMC F/S Jimmy with a 350TBI TH700R4/NP241 with 10 bolts front & rear.
    I was just wondering if this is a "capable" off road transfer case? I've read that it has a great 1:6.4 or something like that L gear, but I just wanted to get some other reviews.
    Also, how hard is it to clock up? Would I have any interfierence problems with the floor pan on a stock body/chasis height?
    Just want to know a few things before I start dreaming about going with a slip yoke conversion kit (and put the splines in the DS, where they should be!). /forums/images/graemlins/ears.gif /forums/images/graemlins/woot.gif
  2. stangfootball34
    stangfootball34 Registered Member
    Aug 21, 2002
    27
    Re: Pro\'s and Con\'s of the NP241 transfer case.
    I know that the np241 which is what I have like's to lose fluid quit often.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The 241 is a pretty good case. It is 2.72 to 1 low range. Just make sure you run a skid plate under it. Installing an SYE is easy. Not sure what you mean by putting the splines in the driveshaft.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    mine dosent leak now after i replaced the seals, the low is lower more like 2 somthing to 1, lightweight, which is good and bad, chain drivin which alot of people dont like. but i think its ok if you dont plan on dooing anything to rough with it
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Nothing wrong with the 241 case. Unless you have a big block and plan on getting really rowdy with it....
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Also make sure to have a good skidplate setup. If that aluminum hits a rock or something you are finished. That aluminum is very thin cast aluminum.
    An SYE kit is a good idea if you plan on offroading hard. The slip yoke is a bad design. If you jump your truck you can destroy the hole case. Don't ask me how I know please. /forums/images/graemlins/doah.gif
    I actually hopped mine of the ground and the slipyoke wouldn't slip fast enough so the driveshaft bent the mainshaft and broke the case apart. I run a 208 but it is the same thing for the most part as a 241.
    Harley
  7. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Ya the ratio for the NP241 is like 6.41 and the NP208 is like 6.08. It's somewhere in ck5's coffers but I'm a lazy prick.
    Remember everyone...
    Lazy is nice, but lathargic is better. /forums/images/graemlins/histerical.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Those are 2's not 6's. Heck I wish.
  9. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    2.72 & 2.61 (41/08 respectivly)
    I could have sworn I found those numbers somewhere on CK5, but I found those specs here;
    http://coloradok5.com/specs.shtml
    Personally I always found 4 low a great way to get stuck. Almost total assurance that I'll get one wheel on each axle to slip.
    Open diffy disease strikes again! /forums/images/graemlins/ignore.gif
  10. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I have a 241 and it has never given me any issues. It is now clocked (which took 5 minutes) and with a 1" body lift it barely touches at full clock (4.5 inches up) I am in the process of building a belly pan so I dont break the case on a rock.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    We rarely see problems with 241s. Usually its just because customers ran them out of oil and burned them up!
  12. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Who makes a kit for clocking the 241? I'm already loooking at the JB Conversions Super Short SYE Kit.
  13. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    There is no kit. You just don't return it to it's stock position, you turn it so the "lobe" is parallel with the ground, instead of pointing down at about 5 o'clock.
    So you need a 1" body lift to clock it up? /forums/images/graemlins/thinking.gif
  14. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    There is a "kit" It requires a clocking ring to do it. I believe it has a few different steps you can clock it to. You don't need to body lift it if you just bash your floor up, but if not it requires 1" BL to clear at the top position. You will probably need new driveshafts or CV shafts to make it all work right. Search on this subject it was covered a lot when the "kits" came out /forums/images/graemlins/waytogo.gif
  15. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I've never done an R&R on a 1990 TH700R4 or a NP241, but I did it in an '85 (NP208) and it looked like if you just twisted it up 1 bolt hole it would work fine. When I was actually doing it, I thought about just trying it. It looks like all the bolts are spaced equally, and there would be no need for any kind of kit? /forums/images/graemlins/thinking.gif
  16. the beast
    Oct 15, 2003
    535
    Providence, RI
    If I have to take it apart for the SYE Kit, I Just going to clock it as well. So I'm already planning on having new shafts made.
    I also have to rebuild all the body mounts, so a 1" lift isn't really that big of a deal.
  17. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    While your in there doing the SYE you may want to look into swapping in the wider chain and sprockets out of a 241HD.
  18. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] the bolts are NOT spaced evenly. This becomes apparent when you try to install a clocking ring, you have to install it just right(aka line up the holes). I've installed mine a few times and realized, oh crap only like 4 of the 5 line up.
  19. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    So I need a spacer kit uh? Duct tape and RTV sealant sounds like enough too me. /forums/images/graemlins/histerical.gif
    There should be a duct tape graemlin. It is the quintessential yankee know how tool. I think it should be on the american flag. /forums/images/graemlins/thinking.gif /forums/images/graemlins/usaflag.gif
  20. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I blew two of them in my Suburban before I switched to a Doubler. I never did figure out why they blew. Maybe it was the 42's?
    As for a SLE, I went with the one from www.drivelinesolutions.com. If you go with their kit I can save you some money by selling you the output yoke I bought from them. Send me a pm.
