Pros vs. cons of a hydro cluch
Discussion in 'The Garage' started by 84CUCV, May 9, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have heard so many different things for other people I don’t know what to believe. I have a 80 with a sm465, I was told the clutch on there now will give me problems twisted up offroad. SO is it worth going to hydro? Any other advice would be appreciated.
    thx mike
  2. davek20
    davek20 Registered Member
    Oct 27, 2004
    16
    i drive a fullsize, i think it might flex a little more than a k5 but my z bar is the worst thing on it, i cant waite to do my clutch swap to put a hydro bell housing, the problem with the z bar ( proably what you have ) is when the frame flexes it makes the space from the bar to the bell houseing and your clutch pedal falls to the floor, ive heard the z bar rod can fall rite off leaving you wtih no clutch, from my expericances its just annoying trying to clutch it going up a rock when the frame flexes it stalls or doesnt engage and its just a **** show, go hydralulic
  3. sagechicken
    sagechicken Registered Member
    Feb 19, 2002
    71
    Wyoming
    I've actually had mine fall out and get lost in a mud hole one trip and had to drive 80+ miles home without a clutch, towing a small boat at that! I started to carry a spare linkage after that. That was on a 76' K5 I had about 10 yrs ago.
  4. poorboy411
    poorboy411 Registered Member
    May 8, 2005
    5
    n.c.
    hey im thinking of going from my th350 to a sm465 and was wandering how other people like em. just wandering if itll be worth the work or not
    dont do much rock climbing just sandy beaches and backwoods muddy paths
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I like my 465 a lot more than the turbo 350 that I used to have. I haven't had a problem with the linkage though.
  6. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    The one time i took my truck offroad i had a lot of problems due to having a mechanical linkage. If i got twisted up at all my clutch would engage at different points but it didnt help that my cab wasnt completely bolted down :whistle: I dont know if my linkage is stock tho, could someone take a picutre of the linkage that connects the zbar to the clutch fork? On my way back the linkage fell out and i found it sitting on my tcase crossmember chillin in some mud :D
    Later
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, if you run good body mounts without a body lift you won't have as much of an issue.
    That being said, there is no way in hell I'd have put a 465 in my wheeling rig if it wasn't hydro. I'd have stuck with a 700R4.
  8. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    I had the problem of the clutch engaging REALLY close to the floor when flexing. Poly body mounts fixed that problem (though I'm sure new rubber mounts would have worked well too). The only real advantage to the hydraulic is that it is easier to push the clutch pedal down. Cons are failed clutch master cylinder/slave cylinder when you need them. I have a manual clutch and have no intentions of swapping to hydraulic (pretty much every hydro clutch will have a failure sometime in its life, mechanical is much more reliable IMHO).
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i dont know of any cons to a hydro clutch.
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I have yet to find one growing on a tree :laugh: :p:
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and i have yet to have a hard time finding one. got one sitting in my garage as a matter of fact.
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Maybe I am not looking hard enough. Around here everything I can find is manual linkage, or else is owned by JK5 :D
  13. dyeager535
    26,980
    I experienced that with the aftermarket master I have, (started leaking with very little usage) but it seems that the stock GM parts are lasting a long time. Even with the leak it worked fine (no idea how long it leaked) and I wouldn't have noticed were it not for the light stream running down the inside of the firewall.
    The master and slave *should* last just as long as a hydraulic brake master cylinder.
  14. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    needs a tether....
    It seems the infamous "Z" bar needs something to keep it from taking a hike when it falls off during a flex!--maybe a peice of wire or cable would keep it from dropping to the ground and dissapearing ,and make it easier to retreive and put back in place--better than driving home with no clutch! :crazy:
  15. 1977k5
    May 26, 2003
    9,995
    133
    I wasn't really trying to dog on hydraulic clutches too much, they are pretty nice. All I was trying to say is that my mechanical clutch has never left my truck stranded in 28 years and 175,000 miles. I have never seen a vehicle with a hydraulic clutch go anywhere near that long without some kind of clutch hydraulic failure that leaves the vehicle stranded (I know it happens, but slave/master cylinders fail with time especially if they are in J**p Cherokees)
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    how many of you had a hydro fail on you? thx
  17. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I've owned my '80 K10 for 14 years, the first 11 with a mechanical linkage, and I never had a problem with it. After converting the truck to one ton, and throwing in a big block, I decided to switch to hydraulic, based on the things I've read on this sight.
    I really like the hydraulic clutch, its way easier to control (less muscle), especially in nerve racking situations. Right now, mine is leaking a bit, so I have to keep an eye on the fluid level. It did take me awhile to find all of the correct GM parts, but it was well worth the swap, especially off road.
  18. 1977k5
    May 26, 2003
    9,995
    133
    Also, I don't know much about 465 slave/master cylinders (they are probably way better than most), just that they generally fail on cars.
  19. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL....Not everything...but I'm working on it. ;)
    I may have one for sale in the very near future. ;)
  20. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my dad has burnt a hole in the line because we didn't check the clearances when we installed the headers. then on the slave cylinder, the end that attaches to the pedal broke off once. other than that in 150,000 miles its fine.
    mine is all 1989 GM stuff and is still working today.
