Protecting Gas Tank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80K5, Aug 9, 2001.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    What have some of you guys done to protect the gas tank. It seems pretty vulnerable left alone.
    Thanks!
    Stuck? Isn't that a bird!
    Steve
  2. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Good topic. I'd like to make a skid plate for mine buy don't know where to bolt it to. Anyone have any pics?
    <a target="_blank" href=http://www.chriswhitley.com>www.chriswhitley.com</a>
  3. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Yeah I have wanted to make one to but not sure on how to attach it.
    Steve
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I have the stock skid plate, can't remember how thick it is but it does it's job. I scraped it on many a rock without any dents. I would find the stocker and use it as a template to make a thicker one
    ~~'84 K5~~
    Check it out at:
    <a target="_blank" href=http://www.k5.rockcrawler.com>www.k5.rockcrawler.com</a>
  5. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have a stock one also it bolts to the cross member front and rear. 'Three bolts on each one I think. It is about 3/16 thick and has held up very well. I would kick around in the junk yards and find one. As a bonus my truck has double cross members under the t-case and the skid plate for the case bolts to both instead of just bolting to the one and sticking straight back.
    I thought I was wrong once,
    but I was mistaken
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I've found the stock '82 skidplate to work pretty well in preventing gouges and tears, but does little to prevent dents. The material is really flexy and it'll push up and dent the tank but never leave a mark on the skidplate. My bumper has done a great job of protecting the tank, the bottom tube is just below it and has taken a real beating.
    Making the world better, one truck at a time.
    SW-ORD
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You might try looking under older rigs in the JY. I got a factory skid plate from a '74 or so Suburban that a guy was parting out. In addition to the bottom plate that the newer ones use, it also has side protection. It's pretty beefy. I got it for $20 and took it off myself to make sure that I got all of the attaching hardware.
  8. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Would this work;if you have bodylift,raise the tank same as the lift is,then fabricate skid plate which bolts to the frame w/crossbars front and rear of the skidplate.I might be doing like that on my K5(when I get it:)).
    I'm too lazy to stick shift,that's why I prefer autotranny.
