Protection for frame mounted fuel pumps
Discussion in 'The Garage' started by Mastiff, Jun 18, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Here's a pic of my new fuel pump mounted on the frame:
    It's in the C-channel above the T-case cross member, so it seems fairly protected from rocks and junk. Does anyone armor them up more?
    The main thing I'm thinking about though, is the electrical connections. They are just sort of hanging out there to get covered with grime and salt or whatever. Do you think I should blob them up with silicone? It'd be easy enough to do, but I wonder what it would be like if I ever have to replace the pump. Will I ever get the silicone off the wire ends, or will I have to cut and resolder/crimp, etc...
    Thoughts?
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I couldn't imagine any rocks or anything getting up inside the C channel of the frame to hurt the fuel pump.
    Personally, I'm more concerned about this fuel pump just going out on me.. Might spend another $100 to have a trail spare so i won't be stranded.
  3. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I try to solder and heat shring every connection made outside the interior compartment. Even if you don't solder it, It's not a bad idea to heat shrink and then put split loom over the wires.
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Looks the exact same as mine. What do you ask for at the parts counter? Mine just came as part of a full TBI conversion kit. It must be stock for some vehicle? Any idea on specs, like pressure and flow, etc?
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Yeah, I've got that covered, but I was thinking of the terminals themselves being directly exposed to the elements. Most OEM connections have a rubber cover or something so salt doesn't land right on them.
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    You could get real fancy and go the junkyard and rob some boots off the wire that normally goes to the alternator. It's got a rubber boot about that size. Put that on and fill it full of dielectric grease and shove it on.
