PS box leak: rebuild or buy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Nov 9, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have a severly leaking PS box. From the appearance of all the fluid, I believe it as evident that the leak is from the box, not the hoses or the pump. Should I even venture into trying to rebuild the box? Looks in good shpae, it is probably just a seal or smoething. Or should I just buy a rebuilt model? Would doing a rebuild myself require any special tools?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    New box vs rebuild.... hmmmm.... lets see. You can get the rebuild kit from AutoZone for $20, or you can spend $300 for a new box?!!! Sounds like a simple question to me! [​IMG][​IMG]
    But if you have some heavy duty stuff under you truck, and like to wheel it hard, the stock box can actually crack. So if you plan to abuse the truck hard, maybe the $300 is the righ way for you to go.
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    It's up to you. You can rebuild the box for fairly cheap (assuming it is just the upper seal that is shot). If the box is very old, abused, sloppy etc. you may want to purchase a new one (perfect chance to do a crossover if you already haven't).
    You can try rebuilding it for the experience and if it lasts then you gained time, and if it still leaks you are only out $20 and some time, but you will alway have the experience.
    Again it's up to you. Good luck either way.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I just went the new box route.I got mine at Napa for $190.
    A balanced diet is a beer in both hands.<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
