PS pulley alignment problems
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by GotLabs, Jan 19, 2007.
  1. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    While converting to PS, I realized that neither pulley I have will work. So which crank pulley do I need. If someone has a pic, or the pulley I need, please post up. Here are the pics of my problem, shallow and deep pulley.
    Also, would the brackets make any difference? I have two sets of those also, both of them different. One is cast, and one is stamped, all help is greatly appreciated.
  2. 69TowRig
    69TowRig 1/2 ton status
    Dec 20, 2004
    288
    Raleigh, NC
  3. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There are several different styles of pumps. The pump you have is an early style with the bolt on pulley. Those are typically used with the short water pump. What year is your engine, better yet which water pump are you running (short or long)? If you're trying to use an early pump with a long water pump it won't work.
  5. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Im using a short pump, the ps setup is off of a 69-72 truck. Im gathering that I need a different crank pulley. The pics I posted are with two different PS pulleys installed.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    So your water pump just about touches the timing cover on the rear side?
  7. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    Yes, very very close.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well then, i'm pretty sure you need the cast iron bracket and a different pulley to make it work.
