ps pulley removal
Discussion in 'The Garage' started by 69K5, Apr 14, 2004.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i cant get the pulley off my ps pump. it was on a m1008. is the allen head reverse threaded pr something. my 2 350 's juyst pressed off. what gives?
    thanks
    69k5
  2. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    you need a power steering pulley puller. The allen does nothing.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yeah go to your local autozone and they will take it off and install it on the new one. /forums/images/graemlins/waytogo.gif
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    im swapping pumps for hydroboost. i just need it off so I can get to the bolts. need to make the hydroboost pump work with 350. wish I had the 6.2 though.
    thanks for the tip ill go get em to taker it off. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Why not just use a regular pump? My hydroboost runs on a regular pump...
    Is the hydro pump a bolt on?
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    everything looks like it will fit fine. has the same studs and holes ect. iwant know until i get em apart. if its off a little then i will make it fit.
    i could use the regular pump but i didnt want to t the lines.
    will i need a ps cooler?
    when i went to autozone there ps pulley puller looked just like mine. ill soak it tonight and try again. if not in the morning i will take it up there.
    69k5
